MBFRC
Bulk Data Entry Defines a constant force at a grid point by specifying a vector.
| MBFRC | SID | G1 | CID | F | G3/N | N | N | G2 | |
| G4 |
| MBFRC | 3 | 345 | 100.0 | 0.0 | 1.0 | 0.0 | |||
| 201 |
| SID | Load set identification number. No default (Integer > 0) | |
| G1 | Grid point identification number where
                the action force is applied. No default (Integer > 0) | |
| CID | Coordinate system identification number.
                Blank or 0 infer the basic coordinate system. Default = 0 (Integer ≥ 0 or blank) | |
| F | Force magnitude. No default (Real) | |
| G3 | Grid point identification number to
                optionally supply N1, N2,
                  N3 in conjunction with G1. (Integer > 0) | |
| N, N, N | Defines the direction of the force
                vector. At least one of the vector components must be non-zero. Default = 0.0 (Real) | |
| G2 | Grid point identification number where
                the reaction force is applied. If blank, the force is an action-only
                  force. Default = blank (Integer > 0 or blank) | |
| G4 | Grid point identification number whose
                parent body hosts the coordinate system with respect to which the force is defined.
                The force vector changes direction with the orientation of the body. If not specified, the force is defined with respect to the ground body (that is the basic coordinate systems). Default = blank (Integer > 0 or blank) |
- This card is represented as a force load in HyperMesh.
