PARAM, CK2
Bulk Data Entry Scale factor for direct input stiffness matrices.
Parameter Values Description
CK2 <Real>
Default = 1.0
CK2 specifies factors for the direct input stiffness matrix. The total stiffness matrix is:
⌊ K jj ⌋ = ⌊ K jj x ⌋ + CK 2 * ⌊ K jj 2 ⌋
Where,
⌊ K jj 2 ⌋
Is selected in the Subcase Information command K2GG.
⌊ K jj x ⌋
Is generated from structural element entries in the Bulk Data section.
