PARAM, CP2
Bulk Data Entry Scale factor for direct input load matrices.
Parameter Values Description
CP2 <Real>
Default = 1.0
CP2 specifies factors for the direct input load matrix. The total load matrix is:
⌊ P j ⌋ = ⌊ P j x ⌋ + CP 2 * ⌊ P j 2 ⌋
Where,
⌊ P j 2 ⌋
Is selected in the Subcase Information command P2G.
⌊ p j x ⌋
Is generated from the static load entries in the Bulk Data section.
