PARAM, TOLRSC
Bulk Data Entry Connecting grid points of the shell element are moved onto the solid face.
Parameter Values Description
TOLRSC <Real>
Default = 0.05
When the RSSCON shell-to-solid element connector is used, the connecting grid points of the shell element are moved onto the solid face if the grid points are close enough. The tolerable distance of the shell grid point to the solid edge or face is ε ⋅ h where h is the height of the solid edge. Rigid body invariance is satisfied with double-precision accuracy if the shell grid points are adjusted.
