/DT/Eltyp/Iflag
Engine Keyword Time step for select entities.
/DT/Eltyp/Iflag
grnd_ID
| Data | Description | SI Unit Example |
| Eltyp | Entity selection:
| Iflag | Node group flag 1 | |
| Scale factor on time step for the option defined by Eltyp. | ||
| Minimum time step for the option defined by Eltyp. 2 | ||
| grnd_ID | Node group
identifier. Read only if Eltyp is NODA and Iflag =1. |
- The Iflag can be only used with Eltyp=NODA.
- If Iflag =1, only the nodes belonging the node group grnd_ID are affected.
- If Iflag =0, all nodes are affected.
- If Eltyp is BEAM, TRUSS, SPRING, NODA or INTER, the value of has no effect.
