Define the Unit System
You can change the unit system using the Unit System Selector or the Preferences. When importing "discrete mesh" files (.stl, .nas, .fem) with unspecified units, select the model unit in the Import Options dialog.
When you enter a number in a field, the appropriate unit is automatically appended. If you enter a unit after a number, the number is converted to the current unit. For example, entering 10 in inside a field where millimeters are the current units results in 254 mm being displayed.
Units are displayed with mixed capitalization for readability, but you can use any combination of upper- and lowercase letters when you enter them.
