Connector for ActiveMQ
Allows connection to Apache’s ActiveMQ message bus on a real-time streaming basis. Specifically, the connector allows Panopticon to subscribe to XML, JSON or FIX based messages that are published on topics. The data format itself is arbitrary, and consequently, the connection includes the message definition.
  1. Enter the following information:
    Property Description
    Broker
    The location of the message broker. Default is tcp://localhost:61616.
    User Id
    The user Id that will be used to connect to the ActiveMQ service.
    Password
    The password to connect to the ActiveMQ service.
    Topic
    ccepts topic in topic://topicname.* format and topicname.*. Therefore, topic://pano.> and pano.> both will work as topic value.
    Default is topic://topicname.*
  2. Select/unselect the Use durable subscription checkbox.
  3. Select the Message Type.
  4. Click    to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
    This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
  5. You can also opt to load or save a copy of the column definition.
  6. Click   to add columns to the MQ connection that represent sections of the message. Then enter or select:
    Name
    Fix Tag/JsonPath/Text Column Index/XPath
    The Fix Tag/JsonPath/Text Column Index/XPath of the source schema.
    Date Format
    Enabled
    Determines whether the message field should be processed.
    Filter
    Defined parameters that can be used as filter. Only available for JSON, Text, and XML message types.
    NOTE: To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
    For example: yyyy-MM-dd HH:mm:ss.SSSSSS
    To delete a column, check its  or all the column entries, check the topmost , then click .
  7. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
  8. For this section:
    Refer to Define Real-Time Settings for more information.
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
