Connector for DolphinDB - Streaming
The DolphinDB streaming connector allows you to connect and subscribe to streaming data using DolphinDB Java Streaming API.
  1. Enter the following information:
    Property Description
    Host
    DolphinDB - Streaming host address.
    Port
    DolphinDB - Streaming host port. Default is 8848.
    User Id
    The user Id that will be used to connect to the DolphinDB - Streaming service.
    Password
    The password to connect to the DolphinDB - Streaming service.
    Select the Show Characters checkbox to display the entered password characters.
    Table
    Table to subscribe against.
  2. Select the From Beginning checkbox to subscribe from the beginning to the latest messages.
    If unselected, you will only be subscribed to the latest messages.
  3. Click Fetch Schema  to retrieve the schema of the configured subscription.
    This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
  4. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
  5. For this section:
    Refer to Define Real-Time Settings for more information.
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
