Connector for Stream Simulator
The Stream Simulator connector is very similar to the Text connector with the addition of the time windowing of message queue connectors.
Creating the Stream Simulator input data source includes setting for how fast and how many messages are pushed through in each batch.
- Select the Text File Source.
The standard settings controlling how the text file is parsed are listed.
These include:
Property Description Skip First N Rows
Specifies the number of rows that will be skipped.
Data Type Discovery
Specifies how many rows from the text file should be used when automatically determining the data types of the resulting columns.
Decimal Separator
Select either the dot (.) or comma (,) as the Decimal Separator.
Text Qualifier
Specifies if fields are enclosed by text qualifiers, and if present, to ignore any column delimiters within these text qualifiers.
Can be any of the following options:
- None
- Single Quote
- Double Quote
Column Delimiter
Specifies the column delimiter to be used when parsing the text file.
First Row Headings
Determines if the first row should specify the retrieved column headings, and not be used in data discovery.
- Click
to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
- You can also opt to load or save a copy of the column definition.
- Click
. A new column entry is displayed. Enter or select the following properties:
Property Description Name
Column Index
The column index controls the position of a column. Must be >= 0. Type
Date Format
Enabled
Determines whether the message field should be processed.
Filter
Defined parameters that can be used as filter. Only available for JSON, Text, and XML message types.
To delete a column, check its
or all the column entries, check the topmost
, then click .
Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
- Select the Simulation Type:
- Record
Sends the number of records for each interval of time. By default, records are sent in the same order as the source.
This simulation type allows the specification of the following:
- Sort Order
When you select Use file sort order, it will use the default sorting order of the file.
When you either select Ascending or Descending as the Sort Order, this enables the Sorted by Column drop down list.
Select the column that will be used for the sorting.
- Playback Set Size
The number of records set to be updated during simulate/playback.
- Start Up Set Size
The number of records set to be published initially (on start-up).
- Playback Interval (ms)
The update interval period for the record-based playback. Default is 1000 (ms).
- Sort Order
- Time
Simulates records as they occur in real-time.
- Playback Column
The playback column which is a Date/Time type.
- Playback Speed
A multiplier which either speed up or slow down the playback. Default is 1.
- If 0 < value < 1 slow down
- If value = 1 records will be published as they occur
- if value > 1 speed up
NOTE: For time-based simulation, if the Date/Time column have improper dates, it will fail and stop.
- Playback Column
- Record
Select the Loop checkbox to enable looping through the file.
For this section:
Refer to Define Real-Time Settings for more information.
