Connector for ksqlDB - Streaming
The ksqlDB - Streaming connector allows executing ksqlDB push queries.
  1. Enter the following information:
    Property Description
    Server URL
    ksqlDB - Streaming host address.
    Username
    User Id that will be used to connect to ksqlDB - Streaming.
    Password
  2. Select the Collection checkbox to enable and select either:
    • Stream
      Immutable and append-only collections which are useful for representing a series of historical facts. Adding multiple events with the same key allows these events to be appended to the end of the stream.
    • Table
      Mutable collections. Adding multiple events with the same key allows the table to only keep the value for the last key. This collection is helpful in modeling change over time and often used to represent aggregations.
  3. Click   to populate the drop-down list. Select the collection.
  4. Enter an SQL-like query language into the Query box.
  5. Select the From Beginning checkbox to subscribe from the beginning to the latest messages.
    If not selected, you will only be subscribed to the latest messages.
  6. Enter the Timeout for the length of time to wait for the server response. The default is 5 (in seconds).
  7. Select either the dot (.) or comma (,) as the Decimal Separator.
  8. Click    to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
    This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
  9. You can also opt to load or save a copy of the column definition.
  10. Click   .  A new column entry is displayed. Enter or select the following properties:
    Name
    Date Format
    Enabled
    Determines whether the message field should be processed.
    To delete a column, check its  or all the column entries, check the topmost , then click .
  11. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
  12. For this section:
    Refer to Define Real-Time Settings for more information.
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
