Deleting Folders
When you delete a folder or subfolder on the Workbooks or Data Library page, its contents will also be deleted which may contain workbooks, data tables, webhooks, and themes.
NOTE:
- The Organization and My Workspace sections cannot be deleted.
- You will not be able to delete a folder if you don’t have permission (i.e., Read, Write, Modify) to any of its contents.
- On the Workbooks or Data Library page, you can do one of the following:
- Right-click on a folder or subfolder on the Folders list then select Remove in the context menu or click Remove
icon from the toolbar, or - Right-click on a folder or subfolder on the List or Grid view then select Remove in the context menu or click Remove
icon from the toolbar.
A notification message displays with the confirmation and contents of the folder that will be deleted.
Example 1: Folder with contents
Select the Confirm checkbox.
Example 2: Folder with no contents
- Click
to remove.
