Include List
The Include List selection mode is a combination of the free text and multiple selection modes. In the dashboard, this mode displays as:
This selection mode supports:
- On demand searching of values and selecting several values. It is useful in cases where there are too many values in the configured column to use a multiple selection mode.
- Selection of all items if there is a configured value for Select All.
When selecting the select all item in the Include List, the parameter will be set to the configured select all value.
The primary use case of the Include List selection mode is to handle columns with large amounts of values. To avoid having to fetch and set the parameter to every value in the column when selecting all items, the select all value should be configured such that the parameterized query returns all items.
For other include list options, see filter include/exclude.
