Modifying Global Parameters
- On the Parameters tab, click the Edit
icon of a parameter.
The Name, Value, and Encrypted controls are enabled.
- Make the necessary changes then click
For the inherited parameters, the Name and Type fields are not editable.
Once the value of the inherited parameter is changed, it is displayed as a global parameter and can also be deleted.
Refreshing Global Parameters
Click
to refresh the values that are being pulled by the workbook models.
