Renaming Workbooks or Folders
A user with the Designer role can rename workbooks and folders.
NOTE: The root folder cannot be renamed.
- You can do one of the following:
- Select a workbook, then right-click or click More Actions
and select Export bundle in the context menu, or - Right-click on a folder and select Export Bundle in the context menu.
Workbook Folder or Subfolder Context Menu
Workbook Context Menu
The Rename Workbook or Rename Folder dialog displays, respectively.
- Enter a new name then click
