Table Visualization Axis
The Y axis of the Table visualization includes the following settings:
Setting Description
Leaf Bar Thickness
The thickness of the leaf or lowest level of data. The default value is 80.
Leaf Label Angle
The Label angle of the leaf or lowest level of data of the crosstab axis. Default is 0, accepts values between -90 and +90.
Inner Bar Thickness
The width or height allocated for the non-leaf components of the crosstab axis in pixels. Default is 80.
Inner Label Angle
The angle of the non-leaf labels. Default is 0, accepts values between -90 and +90.
Row Height
Defines the height of table rows in pixels. For tables created in versions before 2021.1 the configured “Minimum Interval Length” is used. Default is 30.
Word Wrap
Determines whether to wrap the visualization axis text.
Show All Column Levels
Determines whether the space in the text axis should be allocated to all hierarchy levels, whether visible or not.
Show Column Labels
Determines whether column labels are visible or not. Enabled by default.
Show Grid Lines
Determines whether grid lines are visible or not.
Show Zebra Stripes
Determines whether to display alternating row colors (like zebra stripes) in the table.
Foreground
Foreground color of the Y-axis.
Background
Background color of the Y-axis.
(c) 2013-2024 Altair Engineering Inc. All Rights Reserved.
