Atan2
Output atan(u1/u2) of the inputs u1 and u2
Modelica/Blocks/Math
This blocks computes the output y as thetangent-inverse of the input u1 divided byinput u2:
y = atan2( u1, u2 );
u1 and u2 shall not be zero at the same time instant.Atan2 uses the sign of u1 and u2 in order to constructthe solution in the range -180 deg ≤ y ≤ 180 deg, whereasblock Atan gives a solution in the range-90 deg ≤ y ≤ 90 deg.
u1 | implicit | Connector of Real input signal 1 | input | 1 |
u2 | implicit | Connector of Real input signal 2 | input | 2 |
y | implicit | Connector of Real output signal | output | 1 |
