RootMeanSquare
Calculate root mean square over period 1/f
Modelica/Blocks/Math
This block calculates the root mean square of the input signal u over the given period 1/f, using themean block.
Note: The output is updated after each period defined by 1/f.
mo_f | f | Base frequency | Scalar | |
mo_x0 | x0 | Start value of integrator state | Scalar |
mo__modifiers/value | Value |
u | implicit | Connector of Real input signal | input | 1 |
y | implicit | Connector of Real output signal | output | 1 |
