DeMultiplex5
DeMultiplexer block for five output connectors
Modelica/Blocks/Routing
The input connector is split into five output connectors.Note, that the dimensions of the output connector signals have to beexplicitly defined via parameters n1, n2, n3, n4 and n5.
mo_n1 | n1 | Dimension of output signal connector 1 | Scalar | |
mo_n2 | n2 | Dimension of output signal connector 2 | Scalar | |
mo_n3 | n3 | Dimension of output signal connector 3 | Scalar | |
mo_n4 | n4 | Dimension of output signal connector 4 | Scalar | |
mo_n5 | n5 | Dimension of output signal connector 5 | Scalar |
mo__modifiers/value | Value |
u | implicit | Connector of Real input signals | input | 1 |
y1 | implicit | Connector of Real output signals 1 | output | 1 |
y2 | implicit | Connector of Real output signals 2 | output | 2 |
y3 | implicit | Connector of Real output signals 3 | output | 3 |
y4 | implicit | Connector of Real output signals 4 | output | 4 |
y5 | implicit | Connector of Real output signals 5 | output | 5 |
