Extractor
Extract scalar signal out of signal vector dependent on IntegerRealInput index
Modelica/Blocks/Routing
This block extracts a scalar output signal out thevector of input signals dependent on the Integervalue of the additional u index:
y = u [ index ] ;
where index is an additional Integer input signal.
mo_nin | nin | Number of inputs | Scalar | |
mo_allowOutOfRange | allowOutOfRange | Index may be out of range | Scalar | true |
mo_outOfRangeValue | outOfRangeValue | Output signal if index is out of range | Scalar |
mo__modifiers/varname | Variable name | Cell of strings | 'k' | |
mo__modifiers/value | Value |
u | implicit | Connector of Real input signals | input | 1 |
y | implicit | Connector of Real output signal | output | 1 |
index | implicit | input | 2 |
