IdealOpAmp
Ideal operational amplifier (norator-nullator pair)
Modelica/Electrical/Analog/Ideal
The ideal OpAmp is a two-port. The left port is fixed to v1=0 and i1=0(nullator). At the right port both any voltage v2 and any current i2are possible (norator).
mo__modifiers/varname | Variable name | Cell of strings | 'v1' | |
mo__modifiers/value | Value |
p1 | implicit | Positive pin of the left port | input | 1 |
n1 | implicit | Negative pin of the left port | output | 1 |
p2 | implicit | Positive pin of the right port | input | 2 |
n2 | implicit | Negative pin of the right port | output | 2 |
