DiodeBridge2Pulse
Two pulse Graetz diode rectifier bridge
Modelica/Electrical/PowerConverters/ACDC
General information about AC/DC converters can be found at theAC/DC converter concept
This is a two pulse Graetz diode rectifier bridge. The circuit topology is the same as inExamples.ACDC.RectifierCenterTap2Pulse.
mo_RonDiode | RonDiode | Closed diode resistance | Scalar | |
mo_GoffDiode | GoffDiode | Opened diode conductance | Scalar | |
mo_VkneeDiode | VkneeDiode | Diode forward threshold voltage | Scalar | |
mo_useHeatPort | useHeatPort | = true, if heatPort is enabled | Number | 0 |
mo_T | T | Fixed device temperature if useHeatPort = false | Scalar | |
mo_T_heatPort | T_heatPort | T_heatPort | Structure | |
mo_T_heatPort/fixed | fixed | Cell of scalars | true | |
mo_T_heatPort/start | start | Cell of scalars |
mo__modifiers/varname | Variable name | Cell of strings | 'vAC' | |
mo__modifiers/value | Value |
ac_p | implicit | Positive AC input | input | 1 |
ac_n | implicit | Negative AC input | output | 1 |
dc_p | implicit | Positive DC output | input | 2 |
dc_n | implicit | Negative DC output | output | 2 |
Port 5 | implicit | Conditional heat port | input | mo_useHeatPort |
