SignalMagneticFlux
Signal-controlled magnetic flux source
Modelica/Magnetic/FluxTubes/Sources
This source of a magnetic flux is intended for test purposes, e.g., for simulation and subsequent plotting of a softmagnetic material's magnetisation characteristics if used together with a non-linear reluctance element.
mo__modifiers/varname | Variable name | Cell of strings | 'V_m' | |
mo__modifiers/value | Value |
port_p | implicit | Positive magnetic port | input | 1 |
port_n | implicit | Negative magnetic port | output | 1 |
Phi | implicit | Magnetic flux | input | 2 |
