IdealGear
Ideal gear without inertia
Modelica/Mechanics/Rotational/Components
This element characterizes any type of gear box which is fixed in theground and which has one driving shaft and one driven shaft.The gear is ideal, i.e., it does not have inertia, elasticity, dampingor backlash. If these effects have to be considered, the gear has to beconnected to other elements in an appropriate way.
mo_useSupport | useSupport | = true, if support flange enabled, otherwise implicitly grounded | Number | 0 |
mo_ratio | ratio | Transmission ratio (flange_a.phi/flange_b.phi) | Scalar |
mo__modifiers/varname | Variable name | Cell of strings | 'phi_support' | |
mo__modifiers/value | Value |
flange_a | implicit | Flange of left shaft | input | 1 |
flange_b | implicit | Flange of right shaft | output | 1 |
Port 3 | implicit | Support/housing of component | input | mo_useSupport |
