Accelerate
Forced movement of a flange according to an acceleration signal
Modelica/Mechanics/Rotational/Sources
The input signal a defines an angular accelerationin [rad/s2]. Flange flange is forced to move relative to flange support withthis acceleration. The angular velocity w and the rotation anglephi of the flange are automatically determined by integration ofthe acceleration.
The input signal can be provided from one of the signal generatorblocks of the block library Modelica.Blocks.Sources.
mo_useSupport | useSupport | = true, if support flange enabled, otherwise implicitly grounded | Number | 0 |
mo_phi | phi | phi | Structure | |
mo_phi/fixed | fixed | Cell of scalars | true | |
mo_phi/start | start | Cell of scalars | ||
mo_w | w | w | Structure | |
mo_w/fixed | fixed | Cell of scalars | true | |
mo_w/start | start | Cell of scalars |
mo__modifiers/varname | Variable name | Cell of strings | 'phi_support' | |
mo__modifiers/value | Value |
flange | implicit | Flange of shaft | output | 1 |
a_ref | implicit | Absolute angular acceleration of flange with respect to support as input signal | input | 1 |
Port 3 | implicit | Support/housing of component | input | mo_useSupport |
