Convection
Lumped thermal element for heat convection (Q_flow = Gc*dT)
Modelica/Thermal/HeatTransfer/Components
This is a model of linear heat convection, e.g., the heat transfer between a plate and the surrounding air; see also:ConvectiveResistor.It may be used for complicated solid geometries and fluid flow over the solid by determining theconvective thermal conductance Gc by measurements. The basic constitutive equation for convection is
Q_flow = Gc*(solid.T - fluid.T);Q_flow: Heat flow rate from connector 'solid' (e.g., a plate) to connector 'fluid' (e.g., the surrounding air)
Gc = G.signal[1] is an input signal to the component, since Gc isnearly never constant in practice. For example, Gc may be a functionof the speed of a cooling fan. For simple situations,Gc may be calculated according to
Gc = A*hA: Convection area (e.g., perimeter*length of a box)h: Heat transfer coefficient
where the heat transfer coefficient h is calculatedfrom properties of the fluid flowing over the solid. Examples:
Machines cooled by air (empirical, very rough approximation accordingto [Fischer2017, p. 452]:
h = 7.8*v^0.78 [W/(m2.K)] (forced convection) = 12 [W/(m2.K)] (free convection)where v: Air velocity in [m/s]
Laminar flow with constant velocity of a fluid along aflat plate where the heat flow rate from the plateto the fluid (= solid.Q_flow) is kept constant(according to [Holman2010, p.265]):
h = Nu*k/x;Nu = 0.453*Re^(1/2)*Pr^(1/3);where h : Heat transfer coefficient Nu : = h*x/k (Nusselt number) Re : = v*x*rho/mu (Reynolds number) Pr : = cp*mu/k (Prandtl number) v : Absolute velocity of fluid x : distance from leading edge of flat plate rho: density of fluid (material constant mu : dynamic viscosity of fluid (material constant) cp : specific heat capacity of fluid (material constant) k : thermal conductivity of fluid (material constant)and the equation for h holds, provided Re < 5e5 and 0.6 < Pr < 50
mo__modifiers/varname | Variable name | Cell of strings | 'Q_flow' | |
mo__modifiers/value | Value |
Gc | implicit | Signal representing the convective thermal conductance in [W/K] | input | 1 |
solid | implicit | input | 2 | |
fluid | implicit | output | 1 |
