Taking Graph Lakehouse X-Rays from the Command Line
If the Graph Studio Administration application is inaccessible and you need to generate Graph Lakehouse diagnostic files for troubleshooting, you can use the system manager on the Graph Lakehouse leader node to generate the files. The topics in this section provide instructions for generating diagnostic files using the system manager in Graph Lakehouse 2.5 and 3.1 releases. For instructions on retrieving diagnostic files from the Graph Studio Administration application, see Retrieving Graph Lakehouse Diagnostic Files.
