Jump to main content
Altair Feko  2025.1.1 Documentation
2025.1.1
Index
  1. Home
  2. CADFEKO
  3. Quick Tour of the CADFEKO Interface
    View the main elements and terminology in the CADFEKO application window.
  • Welcome
  • Release Notes
  • Get Started
  • Examples
    The Feko Example Guide contains a collection of examples that teaches you Feko concepts and essentials.
  • Introduction to Feko
  • CADFEKO
    • Introduction to CADFEKO
      Use CADFEKO to configure a solver-ready input file for Solver simulations.
    • Quick Tour of the CADFEKO Interface
      • Quick Access Toolbar
        The quick access toolbar is a small toolbar that gives quick access to actions that are often performed.
      • Ribbon
        The ribbon is a command bar that groups similar actions in a series of tabs.
      • Configuration List
        The configuration list displays all configurations in the model.
      • Model Tree
        The model tree contains the variables, named points, the model-creation hierarchy, ports and configuration-specific items of the model. The model tree is split between construction and configuration items.
      • Details Tree
        The details tree panel displays the relevant wires, edges, faces and regions for the geometry or mesh part selected in the Construct tab.
      • Status Bar
        The status bar is the small toolbar that provides access to macro recording, general display settings, tools, selection method and type, snap settings and the model unit.
      • Notes View
        The notes view is a rich-text editor tool that allows you to add comments to your model.
      • Notification Centre
        The Notification centre performs computational electromagnetic model (CEM) validation and shows the status of the model and notifications.
      • 3D View
        3D views are used to display and interact with the model. You can zoom, rotate and pan around a 3D model using the keyboard, mouse or a combination of both. You can use a 3D mouse, specify a view or select specific parts of a model. Multiple 3D views are supported.
      • Navigate the 3D View Using Keyboard and Mouse
        Navigate the 3D view using a mouse, a keyboard or a combination of both.
      • Search Bar
        The search bar is a single-line text field that allows you to enter search terms and find relevant information in the GUI or the documentation.
      • Application Launcher
        The application launcher toolbar is a small toolbar that provides quick access to other Feko components.
      • Application Menu
        The application menu is similar to a standard file menu of an application. It allows saving and loading of models, print functionality and gives access to application-wide settings.
      • Feko Source Data Viewer
        The Feko Source Data Viewer is a tool that allows you to view the currents per frequency for a PCB current data, defined using a .rei file.
      • Help
        The Help icon provides access to the Feko documentation.
      • Dialog Error Feedback
        CADFEKO provides error feedback for dialogs by showing a soft message bubble when validation fails on a dialog.
      • Scripting
        Use the application programming interface (API) to control CADFEKO from an external script.
    • Preferences
      CADFEKO has various default settings that you can configure to customise it to your preference.
    • Compression Level for .CFX and .CFM Files
      For the current model, specify the compression level for the .cfx and .cfm files.
    • Saving a Model
      Store a CADFEKO model and calculation requests to a .cfx file to reopen later.
    • 3D View
    • Model Protection
      Protect a model with a password.
    • Model Definitions
      Define the model unit, variables, named points, workplanes and the model extents for the model.
    • Constructing Geometry
      Create fully parametric and complex CAD geometry using canonical structures and perform Boolean operations on these.
    • Component Library
      The component library contains an extensive list of common components, such as antennas and platforms.
    • Groups
      Organise geometry and mesh parts by grouping geometry and mesh in the model tree.
    • Repairing Geometry
    • Repairing Mesh Parts
      Mesh parts can be manipulated in CADFEKO. Basic mesh editing and fixing capabilities allow triangles to be added, removed and mesh parts to be merged.
    • Importing Models into CADFEKO
      Import a CAD (geometry) model or mesh model from a wide range of industry formats into CADFEKO to save time and development costs.
    • Exporting Models from CADFEKO
      A CADFEKO model can be exported to a variety of industry standard geometry and mesh formats to be used in other applications.
    • Field/Current Data
      Define field or current data using either far field data, near field data, spherical mode data or PCB current data. Use the field/current definition when defining an equivalent source or a receiving antenna.
    • Defining Media
      Define a medium with specific material properties, import a predefined medium from the media library or add a medium from your model to the media library.
    • Applying Media Settings
      Defined media can be applied to the model in various ways. Some media settings are applied to regions, others on faces and wires. The rules for defining media varies between the different solution methods.
    • Periodic Boundary Condition (PBC)
      Use a periodic boundary condition (PBC) to analyse infinite periodic structures. A typical application of PBC is to analyse frequency selective surface (FSS) structures.
    • Finite Antenna Arrays
      Create an arbitrary finite antenna array that consists of an array of contributing elements, either with direct feeds for each element or via indirect coupling, and solve with the efficient domain Green's function method (DGFM).
    • Windscreen Tools
      Use the windscreen tools to define a curved reference surface constrained by a cloud of points, normals and optional U′V′ parameters. The constrained surface is then used as a reference to create a work surface where windscreen layers and curved parameterised windscreen antenna elements can be created.
    • Cables
      Many electromagnetic compatibility and interference problems involve cables that either radiate, are irradiated or cause coupling into other cables, devices or antennas. Use the cable modelling tool and solver to analyse the coupling and radiation.
    • Solution Frequency
      For a frequency domain result, the electromagnetic fields and currents are calculated at a single frequency or frequency range. When the finite difference time domain (FDTD) solver is used, the frequency must be specified to convert the native time domain results to the frequency domain.
    • Power
      The excitation of an antenna is normally specified as a complex voltage, but it may be useful to specify the total radiated or source power instead. The result is then scaled to yield the desired source power level.
    • Ports
      A port is a mathematical representation of where energy can enter (source) or leave a model (sink). Use a port to add sources and discrete loads to a model.
    • Sources
      A source is used to excite or illuminate the model and cause current to flow.
    • Loads and Non-Radiating Networks
      Complex feed networks can be simplified by including them as a circuit representation using general network blocks.
    • Multiple Configurations
      Perform multiple solutions for a single model using multiple configurations. Multiple configurations remove the requirement to create multiple models with different solution requests.
    • Requesting Calculations
      Before running the Solver, define the output requests and view in the model tree (Configuration tab).
    • Infinite Planes and Half-Spaces
      Use an infinite plane or half-space to model a ground plane efficiently. The number of triangles in the model is reduced as the ground plane is not discretised into triangles.
    • Meshing the Geometry / Model Mesh
    • Domain Connectivity
      Domain connectivity approach allows meshes of specific parts to be treated as if connected during MoM and MoM/MLFMM solutions in places where the borders of the meshes are close together, even if the mesh vertices on those borders are not coincident.
    • Working with CADFEKO Models in EDITFEKO
    • Validating the CADFEKO Model
      During the design process, the development of a model can introduce a range of issues that can lead to a non-simulation-ready model. Use the validation toolset to verify that the model is simulation-ready or to search, detect and flag discrepancies.
    • Solver Settings
      The default solver used in Feko is the method of moments (MoM) - surface equivalence principle (SEP). A solver is specified per model, per face or per region, and depends on the solver in question.
    • Component Launch Options
      Specify the command-line parameters for the Feko components.
    • Tools
      CADFEKO has a collection of tools that allows you to quickly validate the model, for example, perform calculations using a calculator, measure distances, measure angles and export images.
    • Model Tree Icons
      View the list of icons that may be found in the model tree.
    • Details Tree Icons
      View the list of icons that may be found in the details tree.
    • Math Functions in CADFEKO
      View the list of supported math functions.
    • Files Generated by CADFEKO
      View the files associated and generated by CADFEKO.
    • Default Shortcut Keys
      View the default shortcut keys available for CADFEKO for faster and easier operation of CADFEKO.
  • POSTFEKO
  • EDITFEKO
  • Feko Solution Methods
  • Optimisation in Feko
  • Feko Utilities
  • Description of the Output File of Feko
  • Feko Application Macros
  • Scripts and Application Programming Interface (API)
  • Appendix
Figure 1. The CADFEKO window.
  1. Quick access toolbar
  2. Ribbon
  3. Configuration list
  4. Model tree
  5. Details tree
  6. Status bar
  7. Model Status
  8. Notes view
  9. Notification Centre
  10. 3D view
  11. Help
  12. Search bar
  13. Application launcher
  • Ribbon
  • Model Tree
  • Details Tree
  • Status Bar
  • Notes View
  • 3D View
  • Search Bar
  • Application Menu
  • Help
  • Scripting
© 2025 Altair Engineering, Inc. All Rights Reserved.
