Default Shortcut Keys
Keyboard shortcut keys help you to save time accessing actions that you perform regularly. The
shortcut key or key combination is also displayed in the keytip that is displayed when you hover
the mouse over the action on the ribbon.
| Shortcut Key | Description |
| Alt+0 | Run CADFEKO. |
| Alt+1 | Run EDITFEKO. |
| Alt+2 | Run PREFEKO. |
| Alt+4 | Run Solver. |
| Alt+6 | Run OPTFEKO. |
| Alt+8 | Open the Feko terminal. |
| General Editing | |
| F1 | Context-sensitive help for the dialog / window that has focus. |
| Ctrl+C | Copy image to clipboard. |
| Ctrl+X | Copy data to clipboard. |
| Ctrl+F | Locate geometry (3D view). |
| Ctrl+F | Find and replace text (script editor). |
| Ctrl+E | Export image. |
| Ctrl+P | Print current window. |
| Ctrl+Shift+O | Open POSTFEKO project file. |
| Ctrl+N | Create a new session. |
| Ctrl+O | Add a model. |
| Ctrl+S | Save POSTFEKO session file. |
| Ctrl+Q | Quit POSTFEKO. |
| Ctrl+Z | Undo |
| Ctrl+Y | Redo. |
| Alt+B | Show / hide the project browser. |
| Alt+B | Show / hide the visibility the project browser. |
| Ctrl+K | Duplicate trace / component. |
| F2 | Rename trace / result. |
| Ctrl+F2 | Change the labels, title and footer of a graph |
| Ctrl+Shift+left click | Add annotation in 3D view or to a Cartesian graph or polar graph. |
| Shift+F2 | Edit trace text. |
| Ctrl++ | Raise trace. |
| Ctrl+- | Lower trace. |
| Del | Delete selected items. |
| View | |
| F5 | Zoom to extents. |
| 0 | Restore view. |
| 8 | Top view. |
| 2 | Bottom view. |
| 5 | Front view. |
| Ctrl+5 | Back view. |
| 4 | Left view. |
| 6 | Right view. |
| 3D View Interaction | |
| Shift + hold while scrolling mouse wheel | Slow zoom (3D view). |
| Scroll mouse wheel | Zoom (3D view). |
| Click + drag with middle mouse button | Panning (3D view, schematic view). |
| Ctrl + click / drag | Panning (3D view). |
| Left click + drag mouse | Rotation (3D view). |
| Script Editor | |
| Ctrl+N | Create a new empty script. |
| Ctrl+O | Open script. |
| Ctrl++ | Zoom in. |
| Ctrl+- | Zoom out. |
| Ctrl+G | Goto line. |
