Version Numbers
Each major release, upgrade or update is assigned a version number. A version number contains a unique set of numbers assigned to a specific software release for identification purposes. You can determine from the version number if its an initial release, update or upgrade.
The following terminology is used to define a version
number:
Feko <Major>.<Minor>.<Patch>for example:
Feko 2019.1.2- 2019
- Indicates the major release version. A major release is made available roughly once a year
and has a minor and patch version of
0
.Note:- The update utility does not support upgrades between major versions.
- A major release requires a new installer.
- 1
- Indicates the minor release version and is referred to as an upgrade. Large feature
enhancements and bug fixes are included in the upgrade. Minor upgrades are released quarterly,
for example
1
indicates the first minor upgrade after the initial release. Use the update utility to upgrade to a newer minor version (when available).
- 2
- Indicates the patch version and is referred to as an update or
hot fix
. Minor feature enhancements and bug fixes are included in the update. Patch updates are released between minor upgrades, for example2
indicates the second patch update after an upgrade.
