Define Preformed Shape
Use the Preformed Shape option to apply a user-defined blank shape in the model in place of the default, flat blank shape.
- After setting up your model and prior to running an analysis, right-click on the model or FE mesh.
From the context menu, select Preformed Shape.
- Run your analysis.
