QUIT
Terminates parsing the input file.
AcuSolve Command
QUIT {parameters}
Qualifier
This command has no qualifier.
This command has no parameters.
This functional command terminates reading (parsing) the input file.
For
example,
ANALYSIS {
title = "test problem"
QUIT # check the commands read up to this point
...This command is typically used for debugging.
Note: The RUN command, which is
typically placed at the end of a file, also terminates the parsing of the input
file. EXIT may also be used as an alternative command name
for QUIT.
