2025.1
Administrative tools to customize your Altair HyperWorks installation.
The HWTK GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HWTK GUI Toolkit commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
View new features for Altair HyperWorks 2025.1.
Quick introduction to Altair HyperWorks products.
Discover the functionality of Altair HyperWorks products with interactive tutorials.
Use the Altair License Utility to determine a managed Altair Licensing ID, check license usage, borrow licenses, and set up managed Altair Units.
Altair Compute Console (ACC) is a utility that allows you to start different Altair HyperWorks Solvers.
Remote Job Submission in Altair Compute Console (ACC) is implemented as an alternative to a local run.
AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2020 (or earlier) to Abaqus 2025.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using the HgTrans GUI or via the HgTrans batch mode.
HvTrans is a result translator for HyperView that translates solver result files to .h3d files.
The -validate, -validatecommand, and -invalidcommand options are used to enable entry widget validation.
Steps and examples for writing a custom widget using the toolkit.
The Cleanup Utility is a script for Windows that removes any custom settings that you may have due to the Altair applications installed.
The Model Identification Tool (MIT) is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The MIT operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
The H3D Validation Tools available are H3D Info and H3D Validate.
Use the Altair HyperWorks Products Uninstaller to remove all files from the installation directory.
