2025.1
View new features for nanoFluidX 2025.1.
nanoFluidX is a software to simulate single and multi-phase flows based on the Lagrangian Particle Method Smoothed Particle Hydrodynamics (SPH).
Platforms, operating systems, and processors supported by nanoFluidX and recommended and required hardware.
Installation options and recommendations for nanoFluidX.
Launch a simulation via a Linux, Windows terminal, or via PBS access.
nanoFluidX prep, shortened as nFX[p], is an auxiliary executable for nanoFluidX intended to eliminate a number of potential user errors during the pre-processing phase.
nanoFluidX companion, also known as nFX[c], is a post-processing tool developed to accompany the nanoFluidX solver allowing for an easier execution of certain post-processing tasks.
nanoFluidX monitor, known as nFX[m], is a single file portable Python executable that is aimed for helping with monitoring a nanoFluidX simulation during runtime.
Set up different restart options.
How to troubleshoot a simulation which fails to run or stops prematurely.
Discover nanoFluidX functionality with interactive tutorials.
Create a nanoFluidX model using SimLab.
nanoFluidX commands and parameters with examples.
Physics and theory for nanoFluidX.
This glossary contains generic messages generated by nanoFluidX, their likely causes, and possible methods to resolve the related issues.
This section provides quick responses to typical and frequently asked questions regarding nanoFluidX.
References used throughout the nanoFluidX manual.
