Standalone Applications Unit Draw
In addition to the applications listed above, there are several standalone applications that draw Altair Units. The following table is a summary of AUs drawn of those applications.
Application AUs License Feature Description
EEvision 55 EEvisionPro Online visualization platform for schematics of circuits, wiring harnesses, and components. Includes all plug-ins and add-ons.
Embed OpenVision No No Add-on for Embed.
Embed Viewer No No Read-only version of Embed.
Embed Basic 1 EmbedBasic Same as EMBED with a 100 block limit.
Embed eDrives 4 EmbedeDrives A comprehensive set of motor control blocks covering AC Induction, BLDC, brushed, PMSM, and stepper motors for simulation, code generation, and HIL.
Embed Digital Power Designer 10 EmbedDigitalPower Used for the design and development of digital power supplies and power conversion equipment. DPD is an Add-on for Embed.
Embed Simulation Edition 10 EmbedSimulation Also known as EmbedSE, is a block diagram and state chart environment for modeling, simulation, analysis, and control system development. In addition to its simulation capabilities, it also supports real time data monitoring and control using National Instruments and other boards as well as OPC, CAN, UDP, Serial, and MQTT.
Embed 21 EmbedCodeGen Also called Embed Professional, is an extension of EMBED Simulation Edition for model-based firmware development supporting all microcontrollers, and with enhanced support for the following: Arduino®, ARM®-Linux® (Raspberry Pi™, AMD64, NVJetson/Nano), STMicroelectronics®, and Texas Instruments™.
ESAComp 6 ESAComp Composite design software. AUs are stacked.
Flow Simulator 50 FSimGUI,
FSimSolver
Integrated flow, heat transfer, and combustion design software that enables mixed fidelity simulations to optimize machine and systems design. GUI levels. First solver instance levels, second plus stacks.
HyperSpice 50 HyperSpice Altair HyperSpice is an analog electronic circuit simulator. It features a command line tool reading input text files written in Spice syntax and a waveform viewer.
Standalone SPICE circuit solver requires 50 AUs. AUs are stacked. See Solver section.
30 HyperSpiceBasic Basic standalone SPICE circuit solver has limit in number of circuit nodes First solver instance levels, second plus stacks. See Solver section.
6 HyperSpiceViewer Spice waveform viewer requires 6 AUs. AUs are leveled.
Material Modeler 35 MaterialModeler A material modeling software that allows you to quickly and accurately process raw test material data and generate required inputs for simulation-ready material cards for the nonlinear behavior of bulk materials like metals and plastics.
PollEx Logic/CAM No PollExEntity Logic, CAM, BOM
PollEx PCB Modeler 10 PollExBasic PCB Modeler (PCB, Real PCB Assembly Viewer, Cross Probe (CP), UPE (Unified Part Editor))
PollEx PCB Verification 30 PollExVerification PCB Design for Manufacturing (DFM), Design for Assembly (DFA), Design for Electrical (DFE), Design for Electrical Plus (DFE+), Logic DFE.
PollEx PCB Verification Post-Processing 21 PollExPostVerification PCB Design for Manufacturing (DFM), Design for Assembly (DFA), Design for Electrical (DFE), Design for Electrical Plus (DFE+), Logic DFE – Result visualization.
PollEx PCB Solver 30 PollExSolver PCB Solvers for signal integrity, power integrity, thermal analysis.
PollEx MFG 30 PollExMFG PollEx Manufacturing options
Altair UDE (formerly named PollEx UDE) Feature-based server PollExUDEServer Feature-based license server with a fixed annual per socket up to 50 users.
4 PollExUDEUser Additional checkout for each client access draws 4 AUs.
PSIM Power Supply 10 PSIMPowerSupply PSIM is a Power Electronics simulation environment with digital and analog control, thermal loss models, battery, and photovoltaic models. Also includes Design Suites for Power Supply and EMI.
PSIM Code Generation 15 PSIMCodeGen PSIM embedded code generation and target support for TI C2000 MCUs.
PSIM Interface 15 PSIMInterface PSIM co-simulation interfaces with Simulink, JMAG, Modelsim, Twin Activate, Embed, and FMI.
PSIM Motor Drive 20 PSIMMotorDrive Includes functionality of Power Supply along with PSIM machine and mechanical load models. Includes Design Suites for Motor Control and HEV.
PSIM Solver 15, Table PSIMSolver PSIMSolver is the new license feature introduced in 2025 for the Solver in PSIM. When a simulation is executed either from within PSIM GUI or from PSIM Solver (standalone), the PSIMSolver license feature is required.
Pulse 30 Pulse Orchestrates meaningful models from the broad workflows required to simulate complex systems of systems to the focused workflows needed to enable fast, reliable, and repeatable modeling, analysis, and optimization.
S-CONCRETE 10 SconcretePro, Sline, SconcreteEtabs, SconcreteEnt Design and detail sections of reinforced concrete beams, columns, and walls or continuous concrete beams to meet regional design code requirements and generate customizable design reports. Includes S-CONCRETE and S-LINE.
S-FRAME 10 SframePro, SsteelPro, Spad, Icd, Sview, Scalc, SframeEnt, SsteelEnt Structural analysis with integrated steel and concrete design solutions enabling structural engineers to model and perform linear or advanced non-linear analysis. Design steel and concrete members to meet regional code requirements, generate design reports, and calculate advanced section properties for non-standard sections. Includes S-FRAME Analysis, S-STEEL, S-PAD, ICD, and S-CALC.
Structural Office 10 StimberPro, StimberCSA, StimberNDS, SfoundationPro, SfoundationACI, SfoundationCSA, SfoundationEURO, Scalc, StimberEnt, StimberAISC, StimberCSAS16, SfoundationEnt Hybrid timber structural analysis with integrated mass timber and foundation design solutions enabling structural engineers to simulate hybrid timber structures constructed from mass timber, steel, and concrete. Design mass timber members and concrete foundations to regional design code requirements, generate design reports, and calculate advanced section properties for non-standard sections. Includes S-TIMBER, S-FOUNDATION, and S-CALC.
StarVision PRO 50 StarVisionPro Debug solutions for advanced electronic SoC (System-on-chip). AUs are leveled.
10 SpiceParser Spice parser. AUs are leveled.
10 RTLParser RTL parser. AUs are leveled.
10 NetlistParser Netlist parser. AUs are leveled.
20 SV_Skill_Export Skill export. AUs are stacked.
10 SV_WaveForm_Analog Analog waveform viewer. AUs are leveled.
10 SV_Parasitic Parasitic analysis package. AUs are leveled.
SpiceVision PRO 20 SpiceVisionPro Creates schematics, circuit fragments and design documentation from Spice netlists. AUs are leveled.
10 SV_Parasitic Parasitic analysis package. AUs are stacked.
GateVision PRO 20 GateVisionPro Graphical gate-level netlist analyzer. AUs are leveled.
RTLvision PRO 25 RTLvisionPro Visualization of large RTL designs including third-party IP and reused blocks. AUs are leveled.
10 RTLparser RTL parser. AUs are leveled.
OmniV 15 MBSE_omniV OmniV empowers open model-based systems engineering (MBSE) practice across systems, simulation, test, product development, and controls engineering by formalizing the development, integration, and use of models to inform enterprise and program decision-making.
FlightStream 50 FlightStream A surface-vorticity, viscous-coupled panel solver for rapid aerodynamic simulation. Capable of modeling incompressible through hypersonic flows.
