Jump to main content
2025.1
Index
  1. Home
  2. Onboarding Resources
    Discover HyperMesh CFD functionality with interactive tutorials and community resources.
  3. Industrial Applications
    Access industrial application workflows through the Altair community.
  • Welcome
  • What's New
    View new features for HyperMesh CFD 2025.1.
  • Get Started
  • Onboarding Resources
    • Step-By-Step Tutorials
    • How To Videos
    • Industrial Applications
    • Online Training Material
      Click here to access online training material.
  • Solution Layers
    Solution-centric workflows allow you to traverse through modeling environments using a dedicated UI layer.
  • Manage Files and Data
  • Convert
    Use the Convert tool to convert entire models between data types.
  • Geometry Repair
    Manage CAD, FE, and 2D parametric sketch geometry.
  • Meshing
    Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
  • Setup
    Prepare your model and run the simulation.
  • Post-Processing
    Post-process the simulation results by creating visualizations and measurements.
  • Design Exploration
    Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
  • Automation
    Automate simulation processes with templates and utility scripts.
  • Solver Help
    More resources for AcuSolve and ultraFluidX solvers.
Particle separation simulation in a harvester machine (AcuSolve - EDEM coupling)
Under-hood simulation of heavy equipment
Battery cooling simulation
Dishwasher drying simulation
Washing machine filling - draining - sloshing simulation
Fuel tank filling - sloshing simulation
Parametric CAD Studies of automotive HVAC duct
Aerodynamics simulation (sedan car)
© 2025 Altair Engineering, Inc. All Rights Reserved.
