Default Tables
  • Applying regulation creates default weld tables per weld type. The default weld tables are assigned to all created weldlines.
  • Editing any weldline will create a new table (General/Evaluation/Location table) that’s assigned to the edited weldline.
  • The following use cases are taken care of while editing the weldlines:
    • Applying weld templates during regulation assignment will create default tables based on weld properties from the template.
    • Updating active weld type (T to L) updates to default table (from T to L).
    • Editing multiple weldlines, will create multiple dependent tables per selected weldline.
The Weld property file from the points context containing weld table properties can be exported and imported, allowing flexibility for weld data editing outside points context.
