LoadMap
<LoadMap>
    <LoadType>fixedpoints</LoadType>
    <DutyCycleFile>C:/Users/nandar/Documents/Fatigue/WeldRunHistory/dvs1608_Run2_20240124_120458/FixedPts_dvs1608_Run2_20240124_120458.rdf</DutyCycleFile>
</LoadMap>
Element Tag Valid Points
<LoadType> File path of the Material csv
<DutyCycleFile>
For Fixed points = Range Definition file (RDF)
For Constant Amplitude = Duty Cycle (XML)
The RDF/XML files are written to Export directory in Weld Run History
Example:
  • FixedPts_<rundirectoryname>.rdf
  • constantamplitude_<rundirectoryname>.xml
Format of RDF and XML duty cycle files
Fixed Point Duty Cycle with 2 events (RDF file)
#HyperLife Weld Certification Fixed Point Range Definition File
#RANGES
*id      ncy      LC1      LC2      LC3      LC4      SF1      SF2      SF3      SF4      *Event
1        2000000  4,0      1,0      5,0      3,0      1        1        1        1        *Event_1
4        2000000  1,0      3,0      4,0      5,0      1        1        1        1        *Event_4
#END
Constant Ampltiude Duty Cycle with 2 events (XML file)
<LoadMapData version="24.000000">
    <LoadMap typeofloading="Time Series">
        <Channel>
            <tabfat Max="1" Min="-1" id="1" type="Constant Amplitude"></tabfat>
            <tabfat Max="1" Min="-1" id="2" type="Constant Amplitude"></tabfat>
            <tabfat Max="1" Min="-1" id="3" type="Constant Amplitude"></tabfat>
            <tabfat Max="1" Min="-1" id="4" type="Constant Amplitude"></tabfat>
        </Channel>
        <FatigueEvents>
            <Event id="2" name="Event_2" repeats="1">
                <Fatload LDM="1" Offset="0" Scale="1" resultfile="" sim="0" subcase="1" tabfatId="1" tabfatName="ConstantAmplitude_1"></Fatload>
                <Fatload LDM="1" Offset="0" Scale="1" resultfile="" sim="0" subcase="3" tabfatId="2" tabfatName="ConstantAmplitude_2"></Fatload>
            </Event>
            <Event id="3" name="Event_3" repeats="1">
                <Fatload LDM="1" Offset="0" Scale="1" resultfile="" sim="0" subcase="4" tabfatId="3" tabfatName="ConstantAmplitude_3"></Fatload>
                <Fatload LDM="1" Offset="0" Scale="1" resultfile="" sim="0" subcase="5" tabfatId="4" tabfatName="ConstantAmplitude_4"></Fatload>
            </Event>
        </FatigueEvents>
        <Fatseq></Fatseq>
    </LoadMap>
</LoadMapData>
The constant amplitude loading format is similar to the Duty Cycle format from HyperLife Basic for Time series loading: Load Map.
Format of LCF (Derived Loadcases)
<LoadCase>
<LCFFile>C:\Users\Downloads\loadcombination_4subcases560.lcf</LCFFile>
</LoadCase>
Table 1.
<LCFFile> File path of the Load Combination file (LCF)
Loadcombination file (LCF) with 3 derived subcases
#PARAM
#LCBAS
1 *"Subcase 1"
2 *"Subcase 1"
3 *"Subcase 1"
#LC
*Id dum LC01 LC01 LC01
600  0    1     0 	0	*"Derived Loadcase 600"
601  0    0     1 	0	*"Derived Loadcase 601"
602  0    0     0 	1	*"Derived Loadcase 602"
#END
