Add a Fit Approach
Add approach to the study.
  1. In the Study Explorer, right-click and select Add from the context menu.
  2. In the Add dialog perform the following steps:
    1. In the Label field, enter a name for the Fit.
    2. For Definition from, select whether to clone the Definition defined in the study Setup or an existing approach.
      By default, the Definition defined in the study Setup is selected.
    3. Under Select Type, select Fit.
    4. Click OK.
A new Fit is added to the Study Explorer.
