Add approach to the study.
In the Study Explorer, right-click and select
Add from the context menu.
In the Add dialog perform the following steps:
In the Label field, enter a name for the Optimization.
For Definition from, select whether to clone the Definition defined in
the study Setup or an existing approach.
By default, the Definition defined in the study Setup is
selected.
Under Select Type, select Optimization.
Click OK.
A new Optimization is added
to the Study Explorer.
