Define Output Responses
An output response is a measurement of system performances, such as weight, volume, displacement, stress, strain, reaction forces, and frequency.
Create and define the output responses that will be used in the studies DOE, Fit, Optimization, and Stochastic approaches.
Output responses may be defined using a combination of results read or extracted from
a file and input variable values. These equations may use the functions available or
external functions, including Compose/OML and Python functions.
HyperStudy uses HyperWorks readers and hence can read the binary output files of most popular CAE solvers.
Additional data can be read using custom external readers and import templates.
Tip: For more information about the supported CAE solvers, reference HyperGraph Solver Interfacing. For more information
about the supported file output files, reference Supported
File Types.
