2025.1
High frequency NVH is an implementation of Statistical Energy Analysis (SEA), and is used to predict and analyze the vibration and acoustic response of complex dynamic systems.
View new features for HyperMesh NVH 2025.1.
Discover NVH functionality with interactive tutorials.
Access the Assemble, Analyze, NVH Tools, NVH Post, and Physics AI ribbons.
File formats supported by HyperMesh NVH.
Keep default configuration options and store user preferences.
Follow this sequence when building a model to define all necessary components.
Explore the HyperMesh NVH user interface.
In the modeling window, use the colored edges in a model to identify SEA entities.
Use the ribbons located at the top of the user interface to quickly access tools and functions.
Use the Symmetry tool to mirror/reflect SEAM entities across a symmetry plane.
Build models.
Apply excitations, analyze the model, and post-process the results.
Follow the order of these tasks to successfully import, visualize, and post-process an XML model file using high frequency NVH and SEAM.
