Import Optimized Data
Use the Optimization tool to automate mapping and update NVH connection parameters and modal parameters with optimized values from OptiStruct generated deterministic optimization output.
This tool is used to read the .csv file that has information on optimized values from the OptiStruct optimization solver run.
From the Assemble ribbon, Mapping tools, click the
Optimization tool.
Select the File name and click
Open.
The corresponding entities in the assembly are updated with the optimized values from .csv.
