Output Settings#
The user can control several aspects of the generated code. The options can be accessed via the hamburger icon ≡ in the top right corner of the Python API Recording dialog.
Figure 1. Output settings.
Option
Code destination
Defines where the generated code is output. Valid options are Python Console, Python File, and Pulse Task.
Function name
Defines the name of the Python function.
Generate verbose code
Expands the code by creating individual variables for every argument.
Show equivalent Tcl commands
Includes equivalent Tcl commands as comments.
Include all functions
Includes view, undo/redo, and similar functions.
Enable deprecated functions
Creates a debug model object that provides access to the deprecated functions.
Append collections
Appends collections when creating collections by attached/adjacent.
Ignore popups
Inserts model.hm_answernext(“yes”) before functions that can trigger a popup.
Use ranges for ID lists
Compresses full ID lists using range function.
Include all split entity classes
Generalizes the code to act on all split entity classes.
Include tips in the comments
Includes tips about available options in the comments.
Include header comments
Includes comments at the top of the code with the information about HyperMesh version, model file, solver interface, data, time, and username.
Use list comprehension for entity lists
Compresses full list of entity objects using list comprehension.
The code destination option Pulse Task lets the user automatically generate a Pulse Task from the recorded code. It requires a Pulse installation which is used to generate the task JSON files and to output them into the Pulse Library. The function arguments are recognized and defined as Task inputs.
Figure 2. Generating a Pulse Task.
The following code snippets demonstrate how various output settings impact the generated code:
Generate verbose code - OFF#
collection = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=[80, 82, 84, 90, 103, 105, 107, 113]))
model.normalsreverse(collection=collection, size=0)
Generate verbose code - ON#
ids = [80, 82, 84, 90, 103, 105, 107, 113]
filterByEnumeration = hm.FilterByEnumeration(ent.Element, ids=ids)
collection = hm.Collection(model, filterByEnumeration)
size = 0
model.normalsreverse(collection=collection, size=size)
Show equivalent Tcl commands - OFF#
collection = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=[17, 18, 19, 20]))
model.maskentitymark(collection=collection, flag=0)
Show equivalent Tcl commands - ON#
# [TCL]: *createmark elements 1 17-20
# [TCL]: *maskentitymark elements 1 0
Include all functions - OFF#
collection = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=[35, 36, 54, 56, 77, 78, 101, 249]))
Include all functions - ON#
model.rotateabout(overridedefault=1, x=865, y=200, z=475)
model.viewset(a00=-0.161329937, a01=-0.986833866, a02=-0.0114705461, a03=0, a10=-0.553105123, a11=0.100036611, a12=-0.827083671, a13=0, a20=0.817341651, a21=-0.127088938, a22=-0.561961767, a23=0, a30=425.411852, a31=23.7688757, a32=333.19761, a33=1, minx=-92.2937276, miny=-1003.27125, maxx=1200.87036, maxy=-693.592482)
model.startnotehistorystate(name="Reverse Normals")
model.endnotehistorystate(name="Reverse Normals")
Enable deprecated functions - OFF#
import hm
import hm.entities as ent
model = hm.Model()
def main():
    component = ent.Component(model, 1)
    propertyid = ent.Property(model, 1)
    component.propertyid = propertyid
    component.materialid = None
    components_collection = hm.Collection(model, hm.FilterByEnumeration(ent.Component, ids=[component.id]))
    collection = hm.Collection(model, hm.FilterByCollection(ent.Element, ent.Component), components_collection)
    # [ERROR]: model.propertyupdate(collection=collection, property_name="property1")
Enable deprecated functions - ON#
import hm
from hm.mdi import apis
model = apis.HmModelDebug()
def main():
Append collections
Append collections - OFF#
collection = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=[78]))
collection_1 = hm.CollectionByAdjacent(model, collection)
model.normalsreverse(collection=collection_1, size=0)
Append collections - ON#
collection = hm.CollectionByAdjacent(model, collection)
Ignore popups
Ignore popups - OFF#
# [TIP]: Command triggers popup window. Enable 'Ignore popups' to ignore it when running the script.
model.deletemodel()
Ignore popups - ON#
model.hm_answernext('yes')
model.deletemodel()
Use ranges for ID lists - OFF#
collection = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=[77, 78, 79, 80, 81, 82]))
Use ranges for ID lists - ON#
collection = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=[*range(77,83)]))
Inlcude all split entity classes
Inlcude all split entity classes - OFF#
loadforce_collection = hm.Collection(model, hm.FilterByEnumeration(ent.LoadForce, ids=[1]))
loadforce_collection.set_items('magnitude', 100)
Inlcude all split entity classes - ON#
loadmoment_collection = hm.Collection(model, hm.FilterByEnumeration(ent.LoadMoment, ids=hm.hwUIntList([])))
loadmoment_collection.set_items('magnitude', 100)
loadconstraint_collection = hm.Collection(model, hm.FilterByEnumeration(ent.LoadConstraint, ids=hm.hwUIntList([])))
loadconstraint_collection.set_items('magnitude', 100)
loadpressure_collection = hm.Collection(model, hm.FilterByEnumeration(ent.LoadPressure, ids=hm.hwUIntList([])))
loadpressure_collection.set_items('magnitude', 100)
loadtemperature_collection = hm.Collection(model, hm.FilterByEnumeration(ent.LoadTemperature, ids=hm.hwUIntList([])))
loadtemperature_collection.set_items('magnitude', 100)
loadflux_collection = hm.Collection(model, hm.FilterByEnumeration(ent.LoadFlux, ids=hm.hwUIntList([])))
loadflux_collection.set_items('magnitude', 100)
loadvelocity_collection = hm.Collection(model, hm.FilterByEnumeration(ent.LoadVelocity, ids=hm.hwUIntList([])))
loadvelocity_collection.set_items('magnitude', 100)
loadacceleration_collection = hm.Collection(model, hm.FilterByEnumeration(ent.LoadAcceleration, ids=hm.hwUIntList([])))
loadacceleration_collection.set_items('magnitude', 100)
Include tips in the comments - OFF#
model.readfile(filename="C:/Users/Temp/my_model.hm", load_cad_geometry_as_graphics=0)
model.deletemodel()
Include tips in the comments - ON#
model.deletemodel()
Include header comments - OFF#
 import hm
 model = hm.Model()
 def main():
    collection = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=[81, 82, 83, 84]))
Include header comments - ON#
 # HyperMesh Python API Code Generator
 # HyperMesh Version: 2025.1
 # Model File: C:/Users/Temp/my_model.hm
 # Solver Interface: OptiStruct
 # Date: April 02, 2025
 # Time: 13:27:47
 # Author: username
 import hm
 model = hm.Model()
 def main():
Use list comprehension for entity lists - OFF#
list = [ent.Node(model, 114), ent.Node(model, 118), ent.Node(model, 119), ent.Node(model, 138)]
direction_vector = [0.999402583,0.0343760811,0.00357038225]
model.dragnodestoformsurface(list=list, direction_vector=direction_vector, distance=40)
Use list comprehension for entity lists - ON#
 list = [ent.Node(model, id) for id in [114, 118, 119, 138]]
