DRESP1 - Responses and Attributes
Responses RTYPE PTYPE ATTA ATTB ATTi EXTN
Mass MASS PTYPE, MAT, or blank - COMB 37, SUM or blank PID, MID, SET ID or blank 1 -
Fraction of mass MASSFRAC PTYPE, MAT, or blank - COMB 37, SUM, or blank PID, MID, SET ID or blank 1 -
Volume VOLUME PTYPE, MAT, or blank Blank or ENCLOSED COMB 37, SUM or blank PID, MID, SET ID or blank 1 -
Fraction of design volume VOLFRAC PTYPE, MAT, or blank - COMB37, SUM, or blank PID, MID, SET ID or blank 1 -
Center of Gravity COG PTYPE, MAT, or blank Center of Gravity item code COMB 37 or blank PID, MID, SET ID or blank 1 -
Moment of Inertia INERTIA PTYPE, MAT, or blank Moment of Inertia item code COMB 37 or blank PID, MID, SET ID or blank 1 -
Compliance of a static subcase COMP PTYPE, MAT, or blank - COMB 37, SUM or blank PID, MID, SET ID or blank 1 -
Static displacement DISP - Static displacement Component - Grid ID -
Mode shape DISP - Component Mode # Grid ID -
Frequency of a normal mode FREQ - Either Normal mode # or Number of Modes (refer to Normal Modes Analysis in Internal Responses) - Frequency Response Subcase ID (refer to Normal Modes Analysis in Internal Responses) -
Eigenvalue of a buckling mode LAMA - Buckling mode # - - -
Static stress of homogenous material STRESS PTYPE or ELEM Static stress item code Cluster Size 6, CORNER 9 or blank PID , EID, SET ID or blank 3 -
Grid Point Stress of homogenous material GPSTR 10 PTYPE or ELEM Static stress item code - PID , EID, SET ID or blank 3 -
Static strain of homogenous material STRAIN PTYPE or ELEM Static strain item code CORNER 9 or blank PID, EID, SET ID or blank 3 -
Static stress in a composite lay-up CSTRESS PCOMP, PCOMPG, PCOMPP, PLY, or ELEM Composite Stress item code ALL, Ply No. or 'G# 4 (Default = 1) or blank 5 PID, EID, SET ID, Ply ID, or blank 3 -
Static strain in a composite lay-up CSTRAIN PCOMP, PCOMPG, PCOMPP, PLY, or ELEM Composite Strain item code ALL, Ply No. or 'G# 4 (Default = 1) or blank 5 PID, EID, SET ID, Ply ID, or blank 3 -
Static failure in a composite lay-up CFAILURE PCOMP, PCOMPG, PCOMPP, PLY, or ELEM Composite Failure item code ALL, Ply No. or 'G# 4 (Default = 1) or blank 5 PID, EID, SET ID, Ply ID, or blank 3 -
Static failure 39 FAILURE PSOLID, PSHELL, or ELEM Failure item code PID, EID, SET ID, or blank 3 -
Static force FORCE PTYPE or ELEM Static force item code - PID, EID, SET ID or blank 3 -
Static SPC Forces (Reaction forces/moments) SPCFORCE - Component ID (1-6) - Degrees of freedom - Grid ID -
Static Grid point forces GPFORCE Grid ID Component ID (1-6) - Degrees of freedom - EID -
Frequency response displacement
OR
Resonance of frequency response displacement
FRDISP - Frequency Response displacement component Frequency Value. (Blank, Real > 0.0 or Character)
OR
FQ-HPK, FQ-FPK, FQ-LAN, FQ-FAN 16
Grid ID LOWFQ, HIGHFQ, SCALE, OCTAVE
Frequency response velocity
OR
Resonance of frequency response velocity
FRVELO - Frequency Response velocity component Frequency Value (Blank, Real > 0.0 or Character)
OR
Frequency response acceleration
OR
Resonance of frequency response acceleration
FRACCL - Frequency Response acceleration component Frequency Value (Blank, Real > 0.0 or Character)
OR
Frequency response stress FRSTRS PTYPE or ELEM Frequency Response Stress item code Frequency Value (Blank, Real > 0.0 or Character) PID, EID, SET ID or blank 3 LOWFQ, HIGHFQ, SCALE, OCTAVE
Frequency response strain FRSTRN PTYPE or ELEM Frequency Response Strain item code Frequency Value (Blank, Real > 0.0 or Character) PID, EID, SET ID or blank 3 LOWFQ, HIGHFQ, SCALE, OCTAVE
Frequency response force FRFORC PTYPE or ELEM Frequency Response Force item code Frequency Value (Blank, Real > 0.0 or Character) PID, EID, SET ID or blank 3 LOWFQ, HIGHFQ, SCALE, OCTAVE
Frequency response equivalent radiated power FRERP - - Frequency Value (Blank, Real > 0.0 or Character) Panel ID LOWFQ, HIGHFQ, SCALE, OCTAVE
Acoustic pressure
OR
Resonance of frequency response acoustic pressure
FRPRES - M-PRES, R-PRES or I-PRES Frequency Value. (Blank, Real > 0.0 or Character)
OR
Powerflow FRFLOW - - - SECTION entry ID -
PSD displacement PSDDISP - PSD/RMS item code Frequency Value. (Blank, Real > 0.0 or Character) GRID ID RANDPS IDLOWFQ, HIGHFQ, SCALE, OCTAVE
PSD velocity PSDVELO - PSD/RMS item code Frequency Value. (Blank, Real > 0.0 or Character) GRID ID RANDPS IDLOWFQ, HIGHFQ, SCALE, OCTAVE
PSD acceleration PSDACCL - PSD/RMS item code Frequency Value. (Blank, Real > 0.0 or Character) GRID ID RANDPS IDLOWFQ, HIGHFQ, SCALE, OCTAVE
PSD stress PSDSTRS PTYPE or ELEM PSD/RMS item code Frequency Value (Blank, Real > 0.0 or Character) PID, EID, SET ID or blank 3 RANDPS IDLOWFQ, HIGHFQ, SCALE, OCTAVE
PSD strain PSDSTRN PTYPE or ELEM PSD/RMS item code Frequency Value (Blank, Real > 0.0 or Character) PID, EID, SET ID or blank 3 RANDPS IDLOWFQ, HIGHFQ, SCALE, OCTAVE
PSD pressure PSDPRES - PRES Frequency Value. (Blank, Real > 0.0 or Character) GRID ID RANDPS IDLOWFQ, HIGHFQ, SCALE, OCTAVE
Resultant Section Forces and Section Moments (DRESP1) RESFORCE - Resultant Component (1,2,3 - Resultant Force; 4,5,6 - Resultant Moment) - SIDi (SECTION Identification Number) -
RMS displacement RMSDISP - PSD/RMS item code RMS, ZCF, or blank 7 GRID ID RANDPS ID
RMS velocity RMSVELO - PSD/RMS item code RMS, ZCF, or blank 7 GRID ID RANDPS ID
RMS acceleration RMSACCL - PSD/RMS item code RMS, ZCF, or blank 7 GRID ID RANDPS ID
RMS stress RMSSTRS PTYPE or ELEM PSD/RMS item code RMS, ZCF, or blank 7 PID, EID, SET ID, or blank 3 RANDPS ID
RMS strain RMSSTRN PTYPE or ELEM PSD/RMS item code RMS, ZCF, or blank 7 PID, EID, SET ID, or blank 3 RANDPS ID
RMS pressure RMSPRES - PRES RMS, ZCF, or blank 7 GRID ID RANDPS ID
Response Spectrum Displacement RSDISP 12 - Response Spectrum Displacement Component - GRID ID -
Response Spectrum Stress RSSTRESS 12 PTYPE or ELEM Response Spectrum Stress item code - PID, EID, SET ID, or blank 3 -
Static compliance weighted across all subcases WCOMP - - - - -
Frequency weighted across reciprocal eigenvalues WFREQ - - - - -
Combined static compliance and frequency index (Combined Compliance Index) COMB - - - - -
Bead discreteness fraction for topography design space (0.0 < BEADFRAC ≤ 1.0) BEADFRAC - - COMB 2 or blank DTPGID or blank 1 -
MBD displacement MBDIS MBREQM MBD Displacement item code MAX, MIN, MAXABS, MINABS MBREQM ID -
MBD velocity MBVEL MBREQM MBD Velocity item code MAX, MIN, MAXABS, MINABS MBREQM ID -
MBD acceleration MBACC MBREQM MBD Acceleration item code MAX, MIN, MAXABS, MINABS MBREQM ID -
MBD force MBFRC MBREQM MBD Force item code MAX, MIN, MAXABS, MINABS MBREQM ID -
MBD expression MBEXPR MBREQE - - MBREQE ID -
Mass of flexible body MBMASS PFBODY - COMB, SUM or blank PFBODY ID -
Center of gravity of flexible body MBCOG PFBODY Center of Gravity item code COMB, SUM or blank PFBODY ID -
Moment of inertia of flexible body MBINER PFBODY Moment of Inertia item code COMB, SUM or blank PFBODY ID -
Fatigue results FATIGUE "PTYPE" or "ELEM" LIFE, DAMAGE or FOS SPWLD or blank PID, EID, SET ID or blank 3 -
Temperature TEMP - - - Grid ID -
Thermal Compliance TCOMP - - - - -
Nodal Flow Pressure (Darcy Flow) FLOWPRES - - - Grid ID -
Velocity from a ESLM ( Radioss Integration) optimization run ESLV - ESL velocity component - Grid ID -
Bore Distortion BOREDST 8 - “ORDER No.” or CIRCUL - BIDi -
Section Properties SECTION - Section Item Codes - SECTION entry ID
Gasket pressure GSKP "PTYPE" 11 - - PID -
Contact pressure CNTP CONTACT PRES - CONTACT
Bulk Data ID
Contact force CNTF CONTACT Contact Force Item Codes - CONTACT
Bulk Data ID
Transient Displacement TDISP - Transient displacement component TIME 13 GRID ID -
Transient Compliance TRCOMP - - - - -
Mean Square of Displacement Difference TMDISPD - Transient displacement component - GRID ID1i
GRID ID1j
GRID ID2i
GRID ID2j 14
Grid-based Dang Van FOS GPFAT “PTYPE” or ELEM FOS - PID, EID, or blank -
Nodal Electric Potential ELPOT - - - GRID ID -
Global Electric Compliance ELCOMP - - - - -
Geometric GEORESP - Geometric item code - GRID ID or EID (15, 17) -
Geometric Deformation GEODEFR - Geometric item code - GRID ID or EID (15, 17) -
References
  1. ATTi can only be blank when PTYPE is also blank and means that all relevant entities will be included. 20
  2. ATTB = COMB - Response represents a single response for the combination of all ATTi entities. 22
  3. ATTi can only be blank when a property type is defined in the PTYPE field (not allowed for "ELEM"), and means that all entities of the defined property type will be selected. 21
  4. ATTB = G# - # is the number of the global ply defined on a PCOMPG. 13
  5. ATTB must be Blank for PLY response type. 13
  6. ATTB = Cluster Size represents the number of elements in a cluster for which Stress Constraints need to be defined. 32
  7. If ATTB is blank for RMS responses, then the default value is RMS .
  8. Multiple Bore Distortion responses may be created depending on the number of rings in the referenced BORE (via BID). One response is created for each ring. If the response is used as optimization objective, MINMAX functionality is recommended. Circularity is also available by setting ATTA field to CIRCUL.
  9. Setting ATTB=CORNER allows for the use of corner stresses or corner strains as responses. This response can only be applied on Solid elements. This response is only supported for Sizing, Shape, and Free-Shape Optimization. Corner stresses, are additionally supported also for Topology optimization.
  10. RTYPE=GPSTR allows for the use of Grid point stresses as responses. This response can only be applied on Solid elements. This response is only supported for Topology, Sizing, Shape, and Free-Shape Optimization.
  11. If RTYPE=GSKP, then PTYPE should be set to PGASK, and the ATTi fields reference PGASK ID’s.
  12. RSDISP response is supported for size, shape, and topology optimization. The TX, TY, TZ, RX, RY, and RZ item codes are supported for Response Spectrum Displacement response.
    RSSTRESS response is supported for size and shape optimization. For ROD, BEAM, BAR elements, all static stress item codes are available for RSTRESS ATTA field. For Shells and Solid elements, similarly static stress item codes are supported, except for Surface Stress (von Mises, Max Principal, and Minor Principal stresses), and Neuber correction (1,2).
  13. If ATTB is specified, the responses are evaluated at the closest time step. If ATTB is blank, then by default the displacement responses at all time steps are evaluated.
  14. GRID ID in ATTi fields should be defined in pairs.
  15. For certain geometric responses, the ATTi fields should be defined using sets of grids consistent with the type of response.
    • ANGLE, DGLINE, AREA3, PXAREA3, PYAREA3, and PZAREA3 require sets of 3 grids.
    • LENGTH, DISTX, DISTY, DISTZ, DIFFX, DIFFY, and DIFFZ require sets of 2 grids.
    • AREA4, PXAREA4, PYAREA4, PZAREA4, VOL4, and DGPLANE require a set of 4 grids.
    • VOL5, VOL6, and VOL8 require sets of 5, 6, and 8 grids, respectively.
    • LOCX, LOCY, and LOCZ require a set of 1 grid.
    If multiple sets are referenced in a single DRESP1 entry, the response is the sum of the results for each set.
  16. Resonance responses are single-value responses measured in hertz. They are activated using ATTB = FQ-HPK, FQ-FPK, FQ-LAN, or FQ-FAN. These responses apply to RTYPE settings of FRDISP, FRVELO, FRACCL or FRPRES and are available only for the magnitudes of displacement, velocity, acceleration (translations or rotations) or pressure.
    Note: resonance responses are not compatible with the OCTAVE option in EXTN.
  17. The geometric responses PXAREA, PYAREA, PZAREA, and AREA require sets of elements to be used in the ATTi fields.
  18. The projected geometric responses PXAREA3, PYAREA3, PZAREA3, PXAREA4, PYAREA4, PZAREA4, PXAREA, PYAREA, and PZAREA require the inclusion of a user-defined coordinate system to define the direction of projection.
