.#.eigv file
The .#.eigv file is an OptiStruct binary data file.
File Creation
This file is created by the Subcase Information Entry EIGVSAVE. The prefix for the file name is controlled by the I/O Option EIGVNAME.
File Contents
| Result | Description |
| Eigenvalue | Eigenvalue results from normal modes analyses. |
- This file is used to store eigenvalue results from normal modes analyses for retrieval by modal frequency response subcases. The EIGVRETRIEVE Subcase Information Entry is used to retrieve values from this file.
- The # in the file name is the integer argument given to EIGVSAVE.
