The structural domain consists of 200 CQUAD4 elements with
linear orthotropic material properties.
E1
3.151E+09
E2
4.162E+08
NU12
0.31
G12
4.392E+08
RHO
381.980
Flutter analysis is performed for a set of Mach numbers (M) = {0.338, 0.499,
0.678, 0.901, 0.96, 1.072, 1.141} for a velocity range of [100, 500] m/s. As can be
seen from a figure in 1, the variation of mass ratios across Mach Number suggests difference in flow
conditions across the experiments. Hence, the density ratios are varied for each
Mach number in separate simulations. More specifically, the flow density follows in
the referenced FOI report 2, which is also listed as:
Mach
ρf (kg/m3)
0.338
1.09854
0.499
0.42770
0.678
0.20818
0.901
0.09945
0.96
0.06338
1.072
0.05514
1.141
0.07833
Comparison of Normal Modes
Mode shape and mode frequency comparisons are as follows. The results from OptiStruct are in agreement with the reference results1.
From the .flt file of the first Mach number (M = 0.338)
simulation, the flutter point (where damping changes its sign) corresponding to the
lowest mode is identified as the 2nd mode with a velocity between 120 m/s
to 124 m/s.
Note: By definition, instability (flutter or divergence) occurs when the
damping values are zero. At this point, if the frequency is zero, then the
instability is due to divergence. Otherwise, the instability is due to
flutter.
Figure 2. Flutter Analysis Summary from .flt
File Plotting the v-g curve, the velocity at this flutter point is 123.19 m/s. This
is the most critical flutter point that needs to be avoided for M = 0.338.Figure 3. Identify Flutter Points. The flutter point corresponding to the lowest velocity is also visually
identified. Figure 4. Identify Frequency Value at Critical Flutter Point from v-f
Curve Plotting the v-f plot for the 2nd mode (corresponding to the
critical flutter point), the frequency value for 2nd mode at a velocity
of 123.19 m/s is determined as 24.19 Hz. In the same way, the flutter speed and
flutter frequency determination was repeated for M = {0.499, 0.678, 0.901, 0.96,
1.072, 1.141}.
Comparison of Flutter Speed Coefficient
The flutter speed coefficient (or flutter speed index, FSI) is calculated from OptiStruct and plotted against M and compared against the
reference plot from Figure 16(a) on page 661.
Where,
Flutter velocity
Streamwise semi chord length at wing root = m
Natural circular frequency of the first uncoupled torsional mode rad/s (This is the 2nd normal
mode for this wing)
Mass ratio
This value was determined for each Mach number from Figure 15 on page
651
Figure 5. Flutter Speed Coefficient versus M Comparison Between
Experimental Reference and OptiStruct Flutter
Analysis
Comparison of Flutter Frequency Ratio
The flutter frequency ratio is calculated from OptiStruct and plotted against M. This is compared against
the reference plot from Figure 16(b) on page 671.
Figure 6. Flutter Frequency Ratio versus M Comparison Between
Analysis
Observations
The flutter speed coefficient and flutter frequency ratio from OptiStruct are comparable to experimental reference
data.
The discrepancy between OptiStruct and
experimental data is expected and consistent with what was reported in
Figure 5 of 3 regarding DLM method.
In realistic conditions, for M ~ 0.75 and above, local pockets of supersonic
flow could occur around the structure. This intermediate regime is denoted
as transonic.
In the flutter speed coefficient versus M plot (Figure 5), the experimental reference data shows a reduction in flutter speed
coefficient around M = 1.0 and this is called the transonic dip.
OptiStruct flutter analysis is capable of
capturing the descent of this dip.
Figure 7. Transonic Dip
Reference
1
E. Carson Yates Jr, “AGARD Standard Aeroelastic Configurations for Dynamic
Response. Candidate Configuration I.-WING 445.6,” NASA Technical Memorandum
I00492. 1987
2 Pahlavanloo, P., “Dynamic aeroelastic simulation of the AGARD 445.6
wing using Edge,” FOI Technical Report FOI-R-2259-SE.
2007
3 Beaubien, R. J., Nitzsche, F., and Feszty, D., “Time and frequency
domain flutter solutions for the AGARD 445.6 wing,” Paper IF-102,
IFASD. 2005
