In the model, a 100x100x100 half space (1/4th model) with 2nd order
CHEXA elements is used. See Figure 2.
Material Properties
Value
Young's modulus (E)
210000
Poisson's ratio ()
0.3
R
30
d
0.1
Figure 2. Model Details
Analytical Results:
These analytical solutions are provided by Popov, 2010. The derivation of the
analytical solution is beyond the technical scope of this document. Some key
variables of the analytical solution are as follows:
The contact area is calculated as:
Where,
Radius of the sphere.
Depth of indentation.
The applied force is calculated as:
Where,
Young's modulus.
Poisson's ratio.
The maximum contact pressure/stress is calculated as:
Results
Table 1.
Pressure/Stress
(Magnitude)
r/a
Analytical Result
OptiStruct (S2S)-Contact
Pressure
8482
8545
0
8350
8200
0.2
7700
7930
0.4
6800
6500
0.6
5100
5240
0.8
0
160
1
Figure 3. Analytical Results versus OptiStruct
Results +
The results from FEA are in good agreement with the analytical solution.Figure 4. Stresses - Z Stress Figure 5. Contact Pressure
