RD-SL-T: 2000 Three Point Bending
Tutorial Level: Beginner This tutorial demonstrates how to setup a three-point bending model using SimLab.
In this lesson you will learn to:
  • Step 1: Create a new bending test from applications section
  • Step 2: Define the bending test parameters from fixture configuration menu
  • Step 3: Define probes resting surface, bending axis
  • Step 4: General contact including all bodies
  • Step 5: Solve and post-process the results
Model Description
This validation test is a common test in the industry.
The support cylinders are fixed, and the test specimen is placed on them. The cylinders have a diameter of 8 mm. The impacting cylinder is moved towards the specimen. The distance between the support cylinders should be selected to be at least 10% within the sample ends.
  • Default material is used (/MAT/LAW1) in this example
  • An imposed displacement of 5 mm is applied on the impacting cylinder
  • Units are Length (mm), Time (s), Mass (Mg), Stress (MPa)
  • Simulation time: Defined in the Engine-File is 0.01 (s)
Prerequisites
To run this simulation, you will need access to a licensed version of Radioss. You will need an internet connection to watch the video tutorials and download the files.
Model Files
Before you begin, copy the file(s) used in this tutorial to your working directory.
Tutorial Video
Visit the SimLab Learning Center to view the 3-Point Bending video tutorial, under Solutions > Structural > Static Stress Analysis > 3-Point Bending.
