/EBCS/MONVOL
Block Format Keyword Describes the elementary boundary conditions.
/EBCS/MONVOL/ebcs_ID | |||||||||
surf_ID | Sensor_ID | monvol_ID |
Definition
ebcs_ID | Elementary boundary condition
identifier. (Integer, maximum 10 digits) |
surf_ID | Surface identifier where flux with
monitored volumes are available. (Integer) |
Sensor_ID | Sensor identifier. (Integer) |
monvol_ID | Monitored volume identifier with which
fluxes are accounted. (Integer) |
- The communication surface must lie on the outer surface of a fluid (ALE or Euler) domain.
- There is no need for the geometry of the fluid domain to be consistent with the monitored volume geometry.
- This EBCS formulation is not compatible with SPMD parallel version.
- Compatible with /MAT/LAW6 only.
