/FUNC_2D
Block Format Keyword Defines a scalar value or a vector value defined on a subset of R 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGsbWaaW baaSqabeaacaaIYaaaaaaa@3928@ .
/FUNC_2D/fct2d_ID
fct2d_title
dim
Each point per line
X Y Z1 Z2 Z3
Definition
fct2d_ID (Mandatory) 2D function identifier.
(Integer, maximum 10 digits)
fct2d_title 2D function title.
dim Dimension of the 2D function values.
1
2
3
X Coordinate 1.
(Real)
Y Coordinate 2.
(Real)
Z1 2D function value along first basis axis.
Z2 2D function value along second basis axis, only used when dim=2 or 3.
Z3 2D function value along third basis axis, only used when dim= 3.
/FUNC_2D/1
for density initialization
#      dim
         1
#                  X                   Y                  Z1
#            X-coord             Y-Coord             density
          0.00000000          0.00000000        109.00000000
          0.00195695          0.00000000        114.00000000
          0.00391389          0.00000000        111.00000000
          0.00587084          0.00000000        109.00000000
          0.00782779          0.00000000        114.00000000
/FUNC_2D/3
for velocity initialization
#      dim
         2
#                  X                   Y                  Z1                  Z2
#            X-coord             Y-Coord          velocity x          velocity y
          0.00097656          0.00097656         -0.00026680         -0.02174114
          0.00097656          0.00292969         -0.00080037         -0.02173459
          0.00097656          0.00488281         -0.00133382         -0.02172149
          0.00097656          0.00683594         -0.00186707         -0.02170185
          0.00097656          0.00878906         -0.00240003         -0.02167567
#enddata
  1. The function may contain any number of points.
